Neye ihtiyacın var
Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
Once the back cover has been removed the battery will be visible.
Pry the battery from the device.
Once the battery has been removed you can see the motherboard.
Unscrew 4 screws on the metal docket using a Phillips head screw driver.
The USB connector can now be taken off of the device.
Using the philips screwdriver, remove the two screws on the mother board.
Place the pry tool between the plastic housing around the LCD screen, and the mother board.
Gently separate the screen housing from the mother board
CAUTION: The screen is still attached to the mother board via another electric ribbon.
2 farklı kişi bu kılavuzu tamamladı.
