Ana içeriğe geç
Samsung TL220 Battery Spring Replacement
Neye ihtiyacın var
    1. Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: adım 1, 2 resimden 1. Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: adım 1, 2 resimden 2.
      • Begin by unscrewing all seven 4 mm phillip's screws located on the outside of the camera.
      • Using the plastic opening tool carefully pry open the camera, lifting the back casing off.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung TL220 Battery Spring Replacement: adım 2, 2 resimden 1. Samsung TL220 Battery Spring Replacement: adım 2, 2 resimden 2.
      • Now that you have the back casing off, gently move the LCD screen from the camera to the right and lay it facing down on the table.
      • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung TL220 Battery Spring Replacement: adım 3, 2 resimden 1. Samsung TL220 Battery Spring Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Unclip the four connectors with the plastic opening tool which holds down the orange film strips.
      • Gently with the tweezers remove the four orange film strips from the connectors.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung TL220 Battery Spring Replacement: adım 4, 2 resimden 1. Samsung TL220 Battery Spring Replacement: adım 4, 2 resimden 2.
      • Once the orange film strips have been released from the connectors, unscrew the Phillips 4 mm silver screw which holds down the top of the camera's frame.
      • With your fingers gently push up the camera's top frame. Once the camera's top frame is off you can than gently remove the camera's front casing off, as well.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung TL220 Battery Spring Replacement: adım 5, 2 resimden 1. Samsung TL220 Battery Spring Replacement: adım 5, 2 resimden 2.
      • Flip the entire camera over so that the lenses are facing upward with the LCD screen showing to the side.
      • Now remove the silver case, seen demonstrated in the picture.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung TL220 Battery Spring Replacement: adım 6, 1 resimden 1.
      • After all the parts are disassembled, you will reach the spring part of the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
chelsa
358 İtibar
3 adet Kılavuz yazıldı
Ekip
3 Tech Girls 3 Tech Girls üyesi
Community
2 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 1,011
