Ana içeriğe geç
Samsung TL220 LCD Screen Replacement
Neye ihtiyacın var
  1. Samsung TL220 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Begin with unscrewing the seven outer screws on the camera. There is one on each corner and then three at the bottom.
  2. Samsung TL220 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
  3. Samsung TL220 LCD Screen Replacement: adım 3, 1 resimden 1.
    • When the back casing is off, gently move the LCD screen to the side.
    • And then remove the three inner screws to remove the inside case.
  4. Samsung TL220 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Unclip the four connectors that hold down the orange copper film strips.
    • Then carefully pull out the three film strips with the ifixit plastic opening tool.
  5. Samsung TL220 LCD Screen Replacement: adım 5, 2 resimden 1. Samsung TL220 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Remove the screw located above the center film strip. This holds the top frame in place.
  6. Samsung TL220 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Unclip the four connectors to release the film strips.
  7. Samsung TL220 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Next unclamp the connector to release the film strip and then you can replace your LCD screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lesley
170 İtibar
1 Kılavuz yazıldı
Ekip
3 Tech Girls 3 Tech Girls üyesi
Community
2 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 692
