Ana içeriğe geç
  1. Remove the cover at the base at the back
    • Remove the cover at the base at the back
  2. Place the TV on a mattress or other soft surface to avoid stress in the TV.
    • Place the TV on a mattress or other soft surface to avoid stress in the TV.
    • By putting a folded blanket in the middle under the TV, the weight of the TV will be distributed more equally. This will help working safely in the next steps.
  3. Loosen and remove the four screws from the holes. Slide the base out of the TV.
    • Loosen and remove the four screws from the holes.
    • Slide the base out of the TV.
  4. Yellow clips are close to crucial electronics. Check and remove the common interface card holder. If this is not done the mainboard can be damaged. Red clips are approximately  40mm from the edge. Yellow clips are 25mm from the edge. Blue clips are at the bottom and green clips are further inside and need be forced out.
    • Yellow clips are close to crucial electronics.
    • Check and remove the common interface card holder. If this is not done the mainboard can be damaged.
    • Red clips are approximately 40mm from the edge. Yellow clips are 25mm from the edge. Blue clips are at the bottom and green clips are further inside and need be forced out.
    • Mark a flathead screwdriver with a piece of tape at 35mm from the head.
    • Stick the flathead screwdriver in the side (paralel to the tv panel). When the screwdriver is turned it should unclip the backpanel.
    • Work around the tv to loosen all clips.
  5. Insert the screwdriver flat into the side of the TV (parallel to the TV panel). When the screwdriver is turned, the clips of the cover come loose. Repeat all the red clips like this. The top of this TV is completely or partially fixed with double-sided tape. use the screwdriver to make room to cut the tape Place something between the back and the frame to prevent the panel from getting stuck again.
    • Insert the screwdriver flat into the side of the TV (parallel to the TV panel). When the screwdriver is turned, the clips of the cover come loose. Repeat all the red clips like this.
    • The top of this TV is completely or partially fixed with double-sided tape. use the screwdriver to make room to cut the tape
    • Place something between the back and the frame to prevent the panel from getting stuck again.
    • Finally, release the yellow clips. Work towards this from the top and do not insert the screwdriver further than 25mm. Do not insert the screwdriver below the yellow marked clips
  6. Release the four blue clips on the bottom by inserting a screwdriver and popping up the rear panel. The back panel should now be loose except for the two green clips. When you are sure that all clips are loose along the edge, you can carefully force the back loose.
    • Release the four blue clips on the bottom by inserting a screwdriver and popping up the rear panel.
    • The back panel should now be loose except for the two green clips. When you are sure that all clips are loose along the edge, you can carefully force the back loose.
  7. Disconnect the two flat cables from the LCD panel. Disconnect the cables from the speaker Carefully pull the speaker off, it is secured with blue rubber plugs.
    • Disconnect the two flat cables from the LCD panel.
    • Disconnect the cables from the speaker
    • Carefully pull the speaker off, it is secured with blue rubber plugs.
  8. Disconnect the cable from the infrared module.
    • Disconnect the cable from the infrared module.
    • Release the clips from the infrared module and remove the infrared module.
  9. Release the four clips at the bottom of the protective metal plate. Remove the metal panel by tilting it and pulling it away. Unscrew the four clips.
    • Release the four clips at the bottom of the protective metal plate.
    • Remove the metal panel by tilting it and pulling it away.
    • Unscrew the four clips.
    • Tilt the circuit and release the circuit from under the metal clips.
  10. Note that the plastic edge keeps the LCD in place. Make sure it has not come off when removing the back cover.
    • Note that the plastic edge keeps the LCD in place. Make sure it has not come off when removing the back cover.
    • Screw four bolts into the back. These will support the TV and prevent the TV from leaning on any crucial components.
    • Now turn the TV over so that it is facing up.
  11. Place the TV towards the edge of the table so that the bottom edge of the TV can be reached. The bottom edge is secured with plastic clips. Loosen it carefully all around. Take extra care with the gold-colored cables of the LCD.
    • Place the TV towards the edge of the table so that the bottom edge of the TV can be reached.
    • The bottom edge is secured with plastic clips. Loosen it carefully all around. Take extra care with the gold-colored cables of the LCD.
    • When the clips are loose all around, the edge can be removed.
  12. The LCD panel is very sensitive. Pay close attention to the circuit vaporized on the LCD.
    • The LCD panel is very sensitive. Pay close attention to the circuit vaporized on the LCD.
    • There are several ways to remove the LCD, the method below was successful for the writer.
    • Tape the LCD panel securely to the back with masking tape. Do not stick the tape over the golden connectors, but stick it between the connectors.
    • Prepare a mattress topped with a blanket folded to follow the curve of the TV.
    • Now that the LCD is properly secured, the TV can be turned over on the mattress with blanket.
    • Now loosen the tape and move the LCD circuit away from the frame.
    • Use the previously installed bolts to lift the frame away from the TV.
    • To prevent the LCD from getting stuck in the casing, it is smart to tilt the frame away.
  13. Detach the plastic sides from the backlight. These must be pulled up. Mark the sides to make reinstallation easier. When all sides are removed, the plates of the backlight can be taped together.
    • Detach the plastic sides from the backlight. These must be pulled up.
    • Mark the sides to make reinstallation easier.
    • When all sides are removed, the plates of the backlight can be taped together.
    • Lift the plates off the TV.
  14. Unclip the connector by squeezing on both sides.
    • Unclip the connector by squeezing on both sides.
    • Loosen the screws from the backlight.
    • The backlight now can be removed.
Sonuç
To reassemble the device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
nl en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Maarten N.
267 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 58
Son 30 gün: 281
Her zaman: 4,927
