Ana içeriğe geç
Samsung U28E510 Jog Button Replacement
Neye ihtiyacın var
  1. Samsung U28E510 Jog Button Replacement, Jog Button: adım 1, 3 resimden 1. Samsung U28E510 Jog Button Replacement, Jog Button: adım 1, 3 resimden 2. Samsung U28E510 Jog Button Replacement, Jog Button: adım 1, 3 resimden 3.
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Jog Button Replacement: adım 2, 2 resimden 1. Samsung U28E510 Jog Button Replacement: adım 2, 2 resimden 2.
    • Flip the monitor over so that it is facedown.
    • remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Jog Button.
  3. Samsung U28E510 Jog Button Replacement: adım 3, 1 resimden 1.
    • Disconnect signal cable to power supply board.
    • Remove and replace jog button.
Sonuç
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
3 farklı kişi bu kılavuzu tamamladı.
Jake Ritter
106 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G1, Banghart Winter 2018 Cal Poly, Team S11-G1, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G1
4 Üyeler
6 adet Kılavuz yazıldı
5 Yorum
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - Yanıt
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - Yanıt
“bn96-32135b “
Gary Deon -
this is the part number i found BN96-32135B
Gary Deon - Yanıt
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 86
Her zaman: 6,528
