Ana içeriğe geç
Samsung U28E510 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung U28E510 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Samsung U28E510 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Samsung U28E510 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the cover and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • Lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Motherboard Replacement: adım 2, 2 resimden 1. Samsung U28E510 Motherboard Replacement: adım 2, 2 resimden 2.
    • Flip the monitor over so that it is facedown.
    • Remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove backing to reveal signal/power board in center.
  3. Samsung U28E510 Motherboard Replacement: adım 3, 2 resimden 1. Samsung U28E510 Motherboard Replacement: adım 3, 2 resimden 2.
    • Ensure to grip the connection plugs when removing wires to prevent damage to wires.
    • Unplug wires connected to supply (one on the left and one on right).
    • Disconnect the signal ribbon cable.
    • Pull the motherboard shield off—it's adhered in place by tape, so some force may be needed.
  4. Samsung U28E510 Motherboard Replacement: adım 4, 2 resimden 1. Samsung U28E510 Motherboard Replacement: adım 4, 2 resimden 2.
    • Lay piece upside down.
    • Use a #2 Phillips screwdriver to remove the two screws that secure the motherboard.
    • Lift the motherboard out of the metal shield.
Sonuç
To reassemble your device, follow these instructions in reverse order. Ensure the bezel snaps in place all around monitor.
3 farklı kişi bu kılavuzu tamamladı.
Melina
154 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G1, Banghart Winter 2018 Cal Poly, Team S11-G1, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 1,378
