Ana içeriğe geç
Samsung UBD KM85C Outer Shell Replacement
Neye ihtiyacın var
  1. Samsung UBD KM85C Outer Shell Replacement, Outer Shell: adım 1, 1 resimden 1.
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. Samsung UBD KM85C Outer Shell Replacement: adım 2, 2 resimden 1. Samsung UBD KM85C Outer Shell Replacement: adım 2, 2 resimden 2.
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. Samsung UBD KM85C Outer Shell Replacement: adım 3, 3 resimden 1. Samsung UBD KM85C Outer Shell Replacement: adım 3, 3 resimden 2. Samsung UBD KM85C Outer Shell Replacement: adım 3, 3 resimden 3.
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Samsung UBD KM85C Outer Shell Replacement: adım 4, 1 resimden 1.
    • Remove the cover from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Breanna Ainsworth
258 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team S2-G1, Johnson Spring 2018 Baylor, Team S2-G1, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 12
Her zaman: 222
