Ana içeriğe geç
Samsung UBD-KM85C Disc Drive Replacement
Neye ihtiyacın var
  1. Samsung UBD-KM85C Disc Drive Replacement, Outer Shell: adım 1, 1 resimden 1.
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung UBD-KM85C Disc Drive Replacement: adım 2, 2 resimden 1. Samsung UBD-KM85C Disc Drive Replacement: adım 2, 2 resimden 2.
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung UBD-KM85C Disc Drive Replacement: adım 3, 3 resimden 1. Samsung UBD-KM85C Disc Drive Replacement: adım 3, 3 resimden 2. Samsung UBD-KM85C Disc Drive Replacement: adım 3, 3 resimden 3.
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung UBD-KM85C Disc Drive Replacement: adım 4, 1 resimden 1.
    • Remove the cover from the device.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung UBD-KM85C Disc Drive Replacement, Disc Drive: adım 5, 1 resimden 1.
    • The disk drive is the large metallic rectangular unit that occupies a third of the space inside the unit.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung UBD-KM85C Disc Drive Replacement: adım 6, 2 resimden 1. Samsung UBD-KM85C Disc Drive Replacement: adım 6, 2 resimden 2.
    • The disk drive has four 6.5mm screws located near each of its corners that hold it onto the frame. Use a #1 Phillips head screwdriver to remove these screws.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung UBD-KM85C Disc Drive Replacement: adım 7, 3 resimden 1. Samsung UBD-KM85C Disc Drive Replacement: adım 7, 3 resimden 2. Samsung UBD-KM85C Disc Drive Replacement: adım 7, 3 resimden 3.
    • The disk drive has two connections to the motherboard that can be disconnected by pulling on the blue plastic tabs.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung UBD-KM85C Disc Drive Replacement: adım 8, 1 resimden 1.
    • Once the connections are unplugged and the screws are removed, the disk drive can be lifted out. The previous steps can be done in the reverse order to replace the part.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Edwards
627 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S2-G1, Johnson Spring 2018 Baylor, Team S2-G1, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G1
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
How do I eject a disk that's stuck in the drive?
Martin Y - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 686
