Ana içeriğe geç
Samsung UBD-KM85C Fan B Replacement
Neye ihtiyacın var
  1. Samsung UBD-KM85C Fan B Replacement, Outer Shell: adım 1, 1 resimden 1.
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. Samsung UBD-KM85C Fan B Replacement: adım 2, 2 resimden 1. Samsung UBD-KM85C Fan B Replacement: adım 2, 2 resimden 2.
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. Samsung UBD-KM85C Fan B Replacement: adım 3, 3 resimden 1. Samsung UBD-KM85C Fan B Replacement: adım 3, 3 resimden 2. Samsung UBD-KM85C Fan B Replacement: adım 3, 3 resimden 3.
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Samsung UBD-KM85C Fan B Replacement: adım 4, 1 resimden 1.
    • Remove the cover from the device.
  5. Samsung UBD-KM85C Fan B Replacement, Fan B: adım 5, 2 resimden 1. Samsung UBD-KM85C Fan B Replacement, Fan B: adım 5, 2 resimden 2.
    • Using a #1 phillips head screwdriver, remove the two 8.1 mm screws in the corners of the fan.
  6. Samsung UBD-KM85C Fan B Replacement: adım 6, 3 resimden 1. Samsung UBD-KM85C Fan B Replacement: adım 6, 3 resimden 2. Samsung UBD-KM85C Fan B Replacement: adım 6, 3 resimden 3.
    • Use your fingers to pinch the white tip of the multicolored wire connecting the fan to the motherboard. While pinching, gently pull up to remove the wires from the motherboard.
  7. Samsung UBD-KM85C Fan B Replacement: adım 7, 1 resimden 1.
    • The fan is now free from its screws and wire and can be freely lifted out of the casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Edwards
627 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S2-G1, Johnson Spring 2018 Baylor, Team S2-G1, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 256
