Ana içeriğe geç
Samsung UBD-M8500 Outer Shell Replacement
Neye ihtiyacın var
  1. Samsung UBD-M8500 Outer Shell Replacement, Outer Shell: adım 1, 1 resimden 1.
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Outer Shell Replacement: adım 2, 1 resimden 1.
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Outer Shell Replacement: adım 3, 1 resimden 1.
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Outer Shell Replacement: adım 4, 1 resimden 1.
    • Remove the cover of the device.
Sonuç
Enrique Howell
401 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 73
