Ana içeriğe geç
Samsung UBD-M8500 Wi-Fi Module Replacement
Neye ihtiyacın var
  1. Samsung UBD-M8500 Wi-Fi Module Replacement, Outer Shell: adım 1, 1 resimden 1.
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Wi-Fi Module Replacement: adım 2, 1 resimden 1.
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Wi-Fi Module Replacement: adım 3, 1 resimden 1.
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Wi-Fi Module Replacement: adım 4, 1 resimden 1.
    • Remove the cover of the device.
  5. Samsung UBD-M8500 Wi-Fi Module Replacement, Wi-Fi Module: adım 5, 1 resimden 1.
    • Looking at the device with the cover removed you should see a black piece with a green sticker on it, that is the Wi-Fi module.
  6. Samsung UBD-M8500 Wi-Fi Module Replacement: adım 6, 3 resimden 1. Samsung UBD-M8500 Wi-Fi Module Replacement: adım 6, 3 resimden 2. Samsung UBD-M8500 Wi-Fi Module Replacement: adım 6, 3 resimden 3.
    • Pull the Wi-Fi module's connector directly out of its motherboard connection.
  7. Samsung UBD-M8500 Wi-Fi Module Replacement: adım 7, 3 resimden 1. Samsung UBD-M8500 Wi-Fi Module Replacement: adım 7, 3 resimden 2. Samsung UBD-M8500 Wi-Fi Module Replacement: adım 7, 3 resimden 3.
    • Remove the four screws from the Wi-Fi module using the Phillips #1 screwdriver.
    • Be mindful of the two hidden screws in the gaps of the black plastic piece.
Bitiş Çizgisi
madison mathis
357 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 55
