Ana içeriğe geç
Samsung WB1100F LCD Screen Replacement
Neye ihtiyacın var
  1. Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: adım 1, 2 resimden 1. Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: adım 1, 2 resimden 2.
    • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
    • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung WB1100F LCD Screen Replacement: adım 2, 2 resimden 1. Samsung WB1100F LCD Screen Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool or spudger if available.
    • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung WB1100F LCD Screen Replacement, LCD Screen: adım 3, 2 resimden 1. Samsung WB1100F LCD Screen Replacement, LCD Screen: adım 3, 2 resimden 2.
    • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung WB1100F LCD Screen Replacement: adım 4, 3 resimden 1. Samsung WB1100F LCD Screen Replacement: adım 4, 3 resimden 2. Samsung WB1100F LCD Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Flip the LCD screen over to reveal the display cable.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jesse Lindsey
581 İtibar
5 adet Kılavuz yazıldı
Ekip
Metro State, Team 1-1, Carpenter SU 2016 Metro State, Team 1-1, Carpenter SU 2016 üyesi
MSU-CARPENTER-SU16S1G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 801
