Giriş
This is a prerequisite guide to take off the back cover assembly.
Neye ihtiyacın var
Remove the 7 screws on the outside of the camera
Two 5 mm PH000 screws on the right side of the camera body
Four 3mm PH000 screws on the bottom and the left side of the camera body.
Use the plastic spundger to push the back casing out. Start from the right side and work your way clockwise around the case.
Bir başkası bu kılavuzu tamamladı.
