Ana içeriğe geç
Samsung WB2100 Back Cover Assembly Replacement
Neye ihtiyacın var
  1. Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: adım 1, 3 resimden 1. Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: adım 1, 3 resimden 2. Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: adım 1, 3 resimden 3.
    • Remove the 7 screws on the outside of the camera
    • Two 5 mm PH000 screws on the right side of the camera body
    • Four 3mm PH000 screws on the bottom and the left side of the camera body.
    • Use the plastic spudger to push the back casing out. Start from the right side and work your way clockwise around the case.
    • The HDMI / AV tab might fall out. this is supposed to happen as it is not screwed into place in the back casing.
  2. Samsung WB2100 Back Cover Assembly Replacement: adım 2, 2 resimden 1. Samsung WB2100 Back Cover Assembly Replacement: adım 2, 2 resimden 2.
    • Disconnect the set of wires from the back casing to the motherboard. Do this by using the plastic spudger to flip the black tab up and the wires will pull out.
    • Unscrew the four 3 mm and two silver 1 mm PH000 screw from the green motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mason Ricks
282 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-3, Remmell Spring 2016 USF Tampa, Team 15-3, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 392
