Ana içeriğe geç
Samsung WB2200F Battery Cover Replacement
Neye ihtiyacın var
  1. Samsung WB2200F Battery Cover Replacement, Battery Cover: adım 1, 2 resimden 1. Samsung WB2200F Battery Cover Replacement, Battery Cover: adım 1, 2 resimden 2.
    • Slide the battery cover door open by simultaneously twisting knob and pushing towards the direction of the arrow on the cover.
  2. Samsung WB2200F Battery Cover Replacement: adım 2, 1 resimden 1.
    • Remove battery by slightly tilting the camera. The battery should slide out.
  3. Samsung WB2200F Battery Cover Replacement: adım 3, 2 resimden 1. Samsung WB2200F Battery Cover Replacement: adım 3, 2 resimden 2.
    • Looking at the inside of the battery door, remove the six 4mm screws using the screw driver with the JIS size 000 head.
  4. Samsung WB2200F Battery Cover Replacement: adım 4, 1 resimden 1.
    • Lift the black tab above the knob.
    • Remove any debris from behind knob or replace the knob.
Sonuç
Rachelle
213 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Landers Spring 2016 UMass Dartmouth, Team 5-4, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 196
