Ana içeriğe geç
Samsung WB2200F Face-plate Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Samsung WB2200F Face-plate Replacement, Battery: adım 1, 1 resimden 1.
    • Place the camera upside down on a hard surface such as a table. Make sure that the battery compartment is visible.
  2. Samsung WB2200F Face-plate Replacement: adım 2, 1 resimden 1.
    • Twist the nob counter-clockwise while pushing cover to the left. Then pull the cover up to reveal the battery.
  3. Samsung WB2200F Face-plate Replacement: adım 3, 1 resimden 1.
    • Slide the blue tab to the right to release the battery.
  4. Samsung WB2200F Face-plate Replacement: adım 4, 1 resimden 1.
    • Carefully slide the battery out of the camera. It can then be replaced with a new battery.
  5. Samsung WB2200F Face-plate Replacement, Face-plate: adım 5, 3 resimden 1. Samsung WB2200F Face-plate Replacement, Face-plate: adım 5, 3 resimden 2. Samsung WB2200F Face-plate Replacement, Face-plate: adım 5, 3 resimden 3.
    • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
  6. Samsung WB2200F Face-plate Replacement: adım 6, 1 resimden 1.
    • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
  7. Samsung WB2200F Face-plate Replacement: adım 7, 1 resimden 1.
    • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
    • Make sure to not damage any of the electronic components of the camera
Sonuç
James Julian
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Landers Spring 2016 UMass Dartmouth, Team 5-4, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G4
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 62
