Ana içeriğe geç
Samsung WB2200F LCD Screen Replacement
Neye ihtiyacın var
  1. Samsung WB2200F LCD Screen Replacement, Face-plate: adım 1, 3 resimden 1. Samsung WB2200F LCD Screen Replacement, Face-plate: adım 1, 3 resimden 2. Samsung WB2200F LCD Screen Replacement, Face-plate: adım 1, 3 resimden 3.
    • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
  2. Samsung WB2200F LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
  3. Samsung WB2200F LCD Screen Replacement: adım 3, 1 resimden 1.
    • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
    • Make sure to not damage any of the electronic components of the camera
  4. Samsung WB2200F LCD Screen Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Using the the screw driver with the JIS size 000 head, unscrew each and every 6mm screw surrounding the LCD screen after taking off the face plate.
  5. Samsung WB2200F LCD Screen Replacement: adım 5, 1 resimden 1.
    • The LCD screen has two layers; the screen on top and the metallic screen protector it lays in. Make sure to take out the screw to the right of both layers that link them together.
  6. Samsung WB2200F LCD Screen Replacement: adım 6, 1 resimden 1.
    • Disconnect the faulty screen from the metallic compartment as well as the motherboard of the camera.
  7. Samsung WB2200F LCD Screen Replacement: adım 7, 1 resimden 1.
    • Place the new screen inside the metallic compartment and make sure it fits perfectly on each side.
  8. Samsung WB2200F LCD Screen Replacement: adım 8, 1 resimden 1.
    • Proceed to insert and tighten screws around the screen which has been placed inside its metallic compartment. Be sure to screw in the main 0.4cm screw that connects both the LCD screen and metallic screen together first.
Sonuç
Rudolf Boampong
195 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Landers Spring 2016 UMass Dartmouth, Team 5-4, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 375
