Ana içeriğe geç
Samsung WB2200F Record Button Replacement
Neye ihtiyacın var
  1. Samsung WB2200F Record Button Replacement, Face-plate: adım 1, 3 resimden 1. Samsung WB2200F Record Button Replacement, Face-plate: adım 1, 3 resimden 2. Samsung WB2200F Record Button Replacement, Face-plate: adım 1, 3 resimden 3.
    • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
  2. Samsung WB2200F Record Button Replacement: adım 2, 1 resimden 1.
    • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
  3. Samsung WB2200F Record Button Replacement: adım 3, 1 resimden 1.
    • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
    • Make sure to not damage any of the electronic components of the camera
  4. Samsung WB2200F Record Button Replacement, Record Button: adım 4, 1 resimden 1.
    • Open up the camera by removing the four 6 mm screws, that hold down the metal cover, using the screw driver with the JIS size 000 head.
  5. Samsung WB2200F Record Button Replacement: adım 5, 1 resimden 1.
    • Gently lift off the metal cover.
  6. Samsung WB2200F Record Button Replacement: adım 6, 1 resimden 1.
    • Clean out any dust or debris from the button interface.
    • Replace faulty button.
Sonuç
Rudolf Boampong
195 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Landers Spring 2016 UMass Dartmouth, Team 5-4, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G4
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 398
