Ana içeriğe geç
Samsung WB350F Menu/Control Buttons Replacement
Neye ihtiyacın var
    1. Samsung WB350F Menu/Control Buttons Replacement, Rear Case: adım 1, 3 resimden 1. Samsung WB350F Menu/Control Buttons Replacement, Rear Case: adım 1, 3 resimden 2. Samsung WB350F Menu/Control Buttons Replacement, Rear Case: adım 1, 3 resimden 3.
      • Remove the wristlet strap.
      • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung WB350F Menu/Control Buttons Replacement: adım 2, 3 resimden 1. Samsung WB350F Menu/Control Buttons Replacement: adım 2, 3 resimden 2. Samsung WB350F Menu/Control Buttons Replacement: adım 2, 3 resimden 3.
      • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
      • There is one silver screw on the bottom and two black screws on each side.
      • Keep the screws together for an easier re-assembly later.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung WB350F Menu/Control Buttons Replacement: adım 3, 3 resimden 1. Samsung WB350F Menu/Control Buttons Replacement: adım 3, 3 resimden 2. Samsung WB350F Menu/Control Buttons Replacement: adım 3, 3 resimden 3.
      • Open the case of the camera using your plastic opening tool.
      • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
      • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung WB350F Menu/Control Buttons Replacement: adım 4, 1 resimden 1.
      • Remove the plastic casing, exposing the inner workings of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung WB350F Menu/Control Buttons Replacement, Screen: adım 5, 2 resimden 1. Samsung WB350F Menu/Control Buttons Replacement, Screen: adım 5, 2 resimden 2.
      • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
      • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung WB350F Menu/Control Buttons Replacement: adım 6, 1 resimden 1.
      • Move the menu button panel to the right as well as the screen.
      • Be careful because each are connected to the camera by a ribbon.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung WB350F Menu/Control Buttons Replacement: adım 7, 1 resimden 1.
      • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung WB350F Menu/Control Buttons Replacement: adım 8, 2 resimden 1. Samsung WB350F Menu/Control Buttons Replacement: adım 8, 2 resimden 2.
      • Remove the silver panel.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung WB350F Menu/Control Buttons Replacement: adım 9, 2 resimden 1. Samsung WB350F Menu/Control Buttons Replacement: adım 9, 2 resimden 2.
      • Flip the screen back over.
      • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung WB350F Menu/Control Buttons Replacement: adım 10, 2 resimden 1. Samsung WB350F Menu/Control Buttons Replacement: adım 10, 2 resimden 2.
      • Carefully detach both ribbons by gently pulling one at a time.
      • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
      • Be sure to pull gently as you do not want to break either ribbon.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: adım 11, 3 resimden 1. Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: adım 11, 3 resimden 2. Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: adım 11, 3 resimden 3.
      • Gently pull the ribbon in order to remove the menu/control button panel.
      • The ribbon isn't secured with a connector and you are able to pull it straight out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Taylor Joubert
273 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 46
Her zaman: 1,732
