Ana içeriğe geç
Samsung WB350F Rear Case Replacement
Neye ihtiyacın var
  1. Samsung WB350F Rear Case Replacement, Rear Case: adım 1, 3 resimden 1. Samsung WB350F Rear Case Replacement, Rear Case: adım 1, 3 resimden 2. Samsung WB350F Rear Case Replacement, Rear Case: adım 1, 3 resimden 3.
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Rear Case Replacement: adım 2, 3 resimden 1. Samsung WB350F Rear Case Replacement: adım 2, 3 resimden 2. Samsung WB350F Rear Case Replacement: adım 2, 3 resimden 3.
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Rear Case Replacement: adım 3, 3 resimden 1. Samsung WB350F Rear Case Replacement: adım 3, 3 resimden 2. Samsung WB350F Rear Case Replacement: adım 3, 3 resimden 3.
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Rear Case Replacement: adım 4, 1 resimden 1.
    • Remove the plastic casing, exposing the inner workings of the camera.
Sonuç
Zachary Bourgault
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 771
