Ana içeriğe geç
Samsung WB350F Screen Replacement
Neye ihtiyacın var
  1. Samsung WB350F Screen Replacement, Rear Case: adım 1, 3 resimden 1. Samsung WB350F Screen Replacement, Rear Case: adım 1, 3 resimden 2. Samsung WB350F Screen Replacement, Rear Case: adım 1, 3 resimden 3.
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Screen Replacement: adım 2, 3 resimden 1. Samsung WB350F Screen Replacement: adım 2, 3 resimden 2. Samsung WB350F Screen Replacement: adım 2, 3 resimden 3.
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Screen Replacement: adım 3, 3 resimden 1. Samsung WB350F Screen Replacement: adım 3, 3 resimden 2. Samsung WB350F Screen Replacement: adım 3, 3 resimden 3.
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Screen Replacement: adım 4, 1 resimden 1.
    • Remove the plastic casing, exposing the inner workings of the camera.
  5. Samsung WB350F Screen Replacement, Screen: adım 5, 2 resimden 1. Samsung WB350F Screen Replacement, Screen: adım 5, 2 resimden 2.
    • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
    • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
  6. Samsung WB350F Screen Replacement: adım 6, 1 resimden 1.
    • Move the menu button panel to the right as well as the screen.
    • Be careful because each are connected to the camera by a ribbon.
  7. Samsung WB350F Screen Replacement: adım 7, 1 resimden 1.
    • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
  8. Samsung WB350F Screen Replacement: adım 8, 2 resimden 1. Samsung WB350F Screen Replacement: adım 8, 2 resimden 2.
    • Remove the silver panel.
  9. Samsung WB350F Screen Replacement: adım 9, 2 resimden 1. Samsung WB350F Screen Replacement: adım 9, 2 resimden 2.
    • Flip the screen back over.
    • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
  10. Samsung WB350F Screen Replacement: adım 10, 2 resimden 1. Samsung WB350F Screen Replacement: adım 10, 2 resimden 2.
    • Carefully detach both ribbons by gently pulling one at a time.
    • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
    • Be sure to pull gently as you do not want to break either ribbon.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Casey Bernier
131 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G2
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Broke my screen, bought a new one on the internet (ebay) and used this tutorial for replacement.
Good photos and every step is clear to follow
Gerald Heidrich - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 1,540
