Ana içeriğe geç
Samsung WB850F Control Panel Replacement
Neye ihtiyacın var
    1. Samsung WB850F Control Panel Replacement, Control Panel: adım 1, 3 resimden 1. Samsung WB850F Control Panel Replacement, Control Panel: adım 1, 3 resimden 2. Samsung WB850F Control Panel Replacement, Control Panel: adım 1, 3 resimden 3.
      • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
      • 2 screws are located on the bottom.
      • 2 screws are located on the left side. (HDMI port)
      • 2 screws are located on the right side of the camera. (Opposite HDMI side)
      FixBot'a Sor
      Yorum Ekle
    2. Samsung WB850F Control Panel Replacement: adım 2, 1 resimden 1.
      • To remove the back screen case, use the blue opening tool to open the case up from the right side.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung WB850F Control Panel Replacement: adım 3, 2 resimden 1. Samsung WB850F Control Panel Replacement: adım 3, 2 resimden 2.
      • Use screwdriver to remove control panel screw.
      • Lift up control panel from the side where the screw was just removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jousling Vazquez
431 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-4, Eyestone Spring 2016 USF Tampa, Team 12-4, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S12G4
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Only problem .. Where can I buy a replacement control panel.
D Traynor - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 1,131
