Ana içeriğe geç
Samsung WB850F Lens Assembly Replacement
Neye ihtiyacın var
  1. Samsung WB850F Lens Assembly  Replacement, Control Panel: adım 1, 3 resimden 1. Samsung WB850F Lens Assembly  Replacement, Control Panel: adım 1, 3 resimden 2. Samsung WB850F Lens Assembly  Replacement, Control Panel: adım 1, 3 resimden 3.
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Lens Assembly  Replacement: adım 2, 1 resimden 1.
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Lens Assembly  Replacement: adım 3, 2 resimden 1. Samsung WB850F Lens Assembly  Replacement: adım 3, 2 resimden 2.
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
  4. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: adım 4, 3 resimden 1. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: adım 4, 3 resimden 2. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: adım 4, 3 resimden 3.
    • Remove the two screws.
    • Gently pry open metal case using Plastic tool openers.
  5. Samsung WB850F Lens Assembly  Replacement: adım 5, 2 resimden 1. Samsung WB850F Lens Assembly  Replacement: adım 5, 2 resimden 2.
    • Gently pull up on the lens connector chip to remove the lens.
  6. Samsung WB850F Lens Assembly  Replacement: adım 6, 1 resimden 1.
    • Insert the new lens to be replaced. Make sure you do not get this tab caught while inserting new lens.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jousling Vazquez
431 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-4, Eyestone Spring 2016 USF Tampa, Team 12-4, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S12G4
4 Üyeler
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
hi I have problem...could you please help me with my camera samsung wb850f
merdaneliyev - Yanıt
I am forward to hearing from you....
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 1,739
