Ana içeriğe geç
Samsung Watch Active Battery Replacement
Neye ihtiyacın var
  1. Samsung Watch Active Battery Replacement, Tools: adım 1, 1 resimden 1.
    • Assemble all your tools
  2. Samsung Watch Active Battery Replacement: adım 2, 1 resimden 1.
    • Turn watch faced down to reveal the screws. Remove the straps by pulling on pin switches to release.
  3. Samsung Watch Active Battery Replacement: adım 3, 2 resimden 1. Samsung Watch Active Battery Replacement: adım 3, 2 resimden 2.
    • remove the 4 screws
  4. Samsung Watch Active Battery Replacement: adım 4, 1 resimden 1.
    • Use the tin metal pry tool to gently penetrate the back.
  5. Samsung Watch Active Battery Replacement: adım 5, 1 resimden 1.
    • Use the metal pry tool as support for the opening blue pick
  6. Samsung Watch Active Battery Replacement: adım 6, 1 resimden 1.
    • Gently Lift the back to reveal a connector, use a tweezer to remove it then you will have access to the back
  7. Samsung Watch Active Battery Replacement: adım 7, 1 resimden 1.
    • Separate back fully from rest of the body
  8. Samsung Watch Active Battery Replacement: adım 8, 1 resimden 1.
    • use tweezer to remove all 3 connectors and remove the screw
    The screw here is not the same as the ones on the back. This one is a phillips head (+).
    Rosalie E. Morgan - Yanıt
    of all the screw bits I have, I don't have this one,lol
    mnmacd - Yanıt
  9. Samsung Watch Active Battery Replacement: adım 9, 1 resimden 1.
    • Use Spudger to lift panel housing from body
  10. Samsung Watch Active Battery Replacement: adım 10, 1 resimden 1.
    • Remove housing from watch body
  11. Samsung Watch Active Battery Replacement: adım 11, 1 resimden 1.
    • Lift off motherboard and use tweezer to lift up bettery connector from the plastic housing
  12. Samsung Watch Active Battery Replacement: adım 12, 1 resimden 1.
    • use spudger to lift battey out of plastic housing
  13. Samsung Watch Active Battery Replacement: adım 13, 1 resimden 1.
    • Separate battery from the plastic body, then install replacement battery
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jimi Aloba
347 İtibar
1 Kılavuz yazıldı
2 Yorum
I have so benefited from this portal , I have now made my own contribution. Hope it helps someone.
Jimi Aloba - Yanıt
Excellent guide Haven't done it yet. Where can I find the battery for this watch, also what type of screwdriver are you using for the 1st 4 screws? None of mine fit it.
mnmacd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 37
Her zaman: 1,385
