Ana içeriğe geç
Samsung Water Filter (Horizontal Filter) Replacement
Neye ihtiyacın var
  1. Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: adım 1, 2 resimden 1. Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: adım 1, 2 resimden 2.
    • Open both French doors for the refrigerator compartment.
  2. Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: adım 2, 2 resimden 1. Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: adım 2, 2 resimden 2.
    • Locate the water filter.
    • On this model, the filter can be found at the bottom of the main compartment, between the crisper drawers.
  3. Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: adım 3, 2 resimden 1. Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: adım 3, 2 resimden 2.
    • Twist the water filter cap counter-clockwise until it's loosened from its housing.
  4. Samsung Water Filter (Horizontal Filter) Replacement: adım 4, 2 resimden 1. Samsung Water Filter (Horizontal Filter) Replacement: adım 4, 2 resimden 2.
    • Pull the water filter straight out of its housing and remove it.
    • When you install the replacement filter, remember to remove the cap on the new filter.
  5. Samsung Water Filter (Horizontal Filter) Replacement: adım 5, 2 resimden 1. Samsung Water Filter (Horizontal Filter) Replacement: adım 5, 2 resimden 2.
    • Run the water to flush the filter and check for leaks for a few minutes.
    • Press reset on the filter indicator.
Sonuç
nicO
15.927 İtibar
88 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
34 Üyeler
597 adet Kılavuz yazıldı
2 Yorum
IS there a difference from the HAF-QIN and the HAF-QIN/EXP
bigjon7379 - Yanıt
Does anyone have instructions on taking out the filter assembly to find where leaks are coming from?
Larry - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 86
Her zaman: 15,550
