Ana içeriğe geç
Samsung YP-P3 Case Backplate Replacement
Neye ihtiyacın var
  1. Samsung YP-P3 Case Backplate Replacement, Case Backplate: adım 1, 1 resimden 1.
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
  2. Samsung YP-P3 Case Backplate Replacement: adım 2, 1 resimden 1.
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
  3. Samsung YP-P3 Case Backplate Replacement: adım 3, 2 resimden 1. Samsung YP-P3 Case Backplate Replacement: adım 3, 2 resimden 2.
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Groeneveld
567 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 5-3, Lauer Spring 2014 Michigan Tech, Team 5-3, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 720
