Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Parçalar
Hiçbir parça belirtilmedi.
  1. Slide the back cover forward toward the top of the device with your thumb.
    • Slide the back cover forward toward the top of the device with your thumb.
  2. The back cover is now separated from the device.
    • The back cover is now separated from the device.
  3. Apply a fingernail or a plastic opening tool to the base of the battery.
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. Lift up gently.  The battery should come up and out.
    • Lift up gently. The battery should come up and out.
  5. The battery is now removed from the device.
    • The battery is now removed from the device.
  6. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  7. Remove the two black .265" screws at the base of the device.
    • Remove the two black .265" screws at the base of the device.
  8. Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  9. Slide the rear case cover toward the top of the device with your thumb to release it.
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  10. The rear case cover can now be separated from the device.
    • The rear case cover can now be separated from the device.
  11. Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
    • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  12. Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
  13. Open the case cover starting on the side most distance from the buttons.
    • Open the case cover starting on the side most distance from the buttons.
  14. Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
    • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
  15. You can now safely remove the front case cover from the device.
    • You can now safely remove the front case cover from the device.
Sonuç
Nicolas Coffey
43 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 3-30, Amido Winter 2012 Cal Poly, Team 3-30, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G30
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,132
