Ana içeriğe geç
SanDisk Sansa C250 Internal Battery Replacement
Neye ihtiyacın var
  1. SanDisk Sansa C250 Internal Battery Replacement, Battery Cover: adım 1, 1 resimden 1.
    • Slide the back cover forward toward the top of the device with your thumb.
  2. SanDisk Sansa C250 Internal Battery Replacement: adım 2, 1 resimden 1.
    • The back cover is now separated from the device.
  3. SanDisk Sansa C250 Internal Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. SanDisk Sansa C250 Internal Battery Replacement: adım 4, 1 resimden 1.
    • Lift up gently. The battery should come up and out.
  5. SanDisk Sansa C250 Internal Battery Replacement: adım 5, 1 resimden 1.
    • The battery is now removed from the device.
  6. SanDisk Sansa C250 Internal Battery Replacement, Rear Case Cover: adım 6, 1 resimden 1.
    • Remove the two black .265" screws at the base of the device.
  7. SanDisk Sansa C250 Internal Battery Replacement: adım 7, 1 resimden 1.
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  8. SanDisk Sansa C250 Internal Battery Replacement: adım 8, 1 resimden 1.
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  9. SanDisk Sansa C250 Internal Battery Replacement: adım 9, 1 resimden 1.
    • The rear case cover can now be separated from the device.
  10. SanDisk Sansa C250 Internal Battery Replacement, Front Case Cover: adım 10, 1 resimden 1.
    • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  11. SanDisk Sansa C250 Internal Battery Replacement: adım 11, 1 resimden 1.
    • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
  12. SanDisk Sansa C250 Internal Battery Replacement: adım 12, 1 resimden 1.
    • Open the case cover starting on the side most distance from the buttons.
  13. SanDisk Sansa C250 Internal Battery Replacement: adım 13, 1 resimden 1.
    • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
  14. SanDisk Sansa C250 Internal Battery Replacement: adım 14, 1 resimden 1.
    • You can now safely remove the front case cover from the device.
  15. SanDisk Sansa C250 Internal Battery Replacement, Internal Battery: adım 15, 1 resimden 1.
    • CAUTION: If using a fingernail, be careful not to hurt yourself on the connector.
    • Using a spudger or flat tool, lift the battery up and away from the board, taking note of its orientation.
  16. SanDisk Sansa C250 Internal Battery Replacement: adım 16, 1 resimden 1.
    • Desolder the connectors on both sides of the battery to remove it.
    • Resolder on a new Panasonic 6Y3 micro cell battery, taking care to orient it correctly as noted in the previous step.
    • Bend the battery back so that it's flat against the board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Burke
55 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-30, Amido Winter 2012 Cal Poly, Team 3-30, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G30
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 3,037
