Ana içeriğe geç
Sandal Brooch Replacement
Neye ihtiyacın var
  1. Sandal Brooch Replacement, Brooch: adım 1, 3 resimden 1. Sandal Brooch Replacement, Brooch: adım 1, 3 resimden 2. Sandal Brooch Replacement, Brooch: adım 1, 3 resimden 3.
    • Unwind about 10" of thread. Cut and thread through the needle. Tie a double knot at the end of the thread.
  2. Sandal Brooch Replacement: adım 2, 2 resimden 1. Sandal Brooch Replacement: adım 2, 2 resimden 2.
    • The threads and empty holes show exactly where to attach the shoe ornament.
    • Cut off the old threads.
  3. Sandal Brooch Replacement: adım 3, 2 resimden 1. Sandal Brooch Replacement: adım 3, 2 resimden 2.
    • Start the threaded needle on the upper side of the sandal.
    • The ornament will hide the knot.
    • If pushing the needle through the sandal strap is difficult, you might try turning the sandal at an angle and using your flat surface as a pressing point.
  4. Sandal Brooch Replacement: adım 4, 1 resimden 1.
    • Pull the thread through the ornament's opening.
    • Be careful—needles are sharp!
  5. Sandal Brooch Replacement: adım 5, 3 resimden 1. Sandal Brooch Replacement: adım 5, 3 resimden 2. Sandal Brooch Replacement: adım 5, 3 resimden 3.
    • Pull the thread down and through the sandal straps.
    • Repeat the process, catching the ornament in a variety of places to anchor several sides.
  6. Sandal Brooch Replacement: adım 6, 2 resimden 1. Sandal Brooch Replacement: adım 6, 2 resimden 2.
    • Pull the thread so that the ornament is tight against the sandal.
    • Remember to beware of that sharp needle!
  7. Sandal Brooch Replacement: adım 7, 1 resimden 1.
    • Run the needle back through the sandal strap, then tie a knot at the base of the thread.
    • Double the knot before using your scissors to cut the thread.
    • Cut the thread just above the knot.
    • Be careful—scissors are sharp.
  8. Sandal Brooch Replacement: adım 8, 1 resimden 1.
    • Completed sandal—ready to wear!
Sonuç
Enjoy wearing the sandals!
KaC
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 106
