Ana içeriğe geç
Sanitaire SC684 Roller Brusher and Drive Belt Replacement
  1. Sanitaire SC684 Roller Brusher and Drive Belt Replacement, Roller Brush and Belt: adım 1, 1 resimden 1.
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay the vacuum on its back.
  2. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: adım 2, 1 resimden 1.
    • Find the metal plate (located directly in the center).
    • Locate the two latches on either side of the metal plate.
    • Detach the latches by pulling them away from metal plate.
  3. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: adım 3, 1 resimden 1.
    • Remove the metal plate by pulling it towards you.
  4. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: adım 4, 1 resimden 1.
    • Identify the belt and brush roller.
    • The belt is a black ring made of rubber.
    • The brush roller is the long metal tube with bristles attached to it.
  5. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: adım 5, 1 resimden 1.
    • Remove the belt from the circular knob by inserting your fingers on either side, gently lifting towards you.
  6. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: adım 6, 2 resimden 1. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: adım 6, 2 resimden 2.
    • Pull brush roller out and slip the belt off from the indent in the middle of the roller.
Sonuç
Caycie Pascual
1 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-58, Forte Fall 2012 Cal Poly, Team 16-58, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G58
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 2,793
