Giriş
This guide will teach you how to replace the roller brush and driver belt from your Sanitaire SC684 vacuum cleaner. Sanitaire recommends replacing the roller brush once a year and the belt every six months, to ensure that your vacuum will continue to work optimally.This is a relatively simple procedure that does not require any special skills or tools. These two components are connected, allowing them to be removed at the same time. Reassembly is the same process as removal, reversing the steps.
