Ana içeriğe geç
Sanitaire SC684 front wheel replacement
Neye ihtiyacın var
  1. Sanitaire SC684 front wheel replacement, Front Wheels: adım 1, 1 resimden 1.
    • Be sure to unplug the vacuum before disassembling it to prevent electric shock.
    • Lay the vacuum on its side.
    • Using a Phillips #1 screwdriver, unscrew the screws located behind the front wheels on the underside of the vacuum.
  2. Sanitaire SC684 front wheel replacement: adım 2, 2 resimden 1. Sanitaire SC684 front wheel replacement: adım 2, 2 resimden 2.
    • Stand the vacuum upright, unscrew the single screw located on the center dial using a Torx T20 screwdriver and remove the dial form the vacuum body.
  3. Sanitaire SC684 front wheel replacement: adım 3, 1 resimden 1.
    • Lift the top cover off of the vacuum.
  4. Sanitaire SC684 front wheel replacement: adım 4, 1 resimden 1.
    • Identify the two gray metal plates at the front of the vacuum.
    • Using the T20 Torx screwdriver, remove the four screws on the smaller gray plate holding the larger gray metal plates.
  5. Sanitaire SC684 front wheel replacement: adım 5, 2 resimden 1. Sanitaire SC684 front wheel replacement: adım 5, 2 resimden 2.
    • Remove the small metal plate with the black bolt in the center and the larger gray plate from both sides.
  6. Sanitaire SC684 front wheel replacement: adım 6, 2 resimden 1. Sanitaire SC684 front wheel replacement: adım 6, 2 resimden 2.
    • Pull out the silver bar that holds the two wheels to the vacuum body and detach the small spring from the vacuum body.
  7. Sanitaire SC684 front wheel replacement: adım 7, 2 resimden 1. Sanitaire SC684 front wheel replacement: adım 7, 2 resimden 2.
    • Remove the wheel from the side with the spring by pulling it off the axel and slide off the spring, as it will be needed for the replacement front wheels.
Sonuç
Caycie Pascual
1 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-58, Forte Fall 2012 Cal Poly, Team 16-58, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G58
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 1,132
