Ana içeriğe geç
Sansa e260R Front Panel Replacement
Neye ihtiyacın var
  1. Sansa e260R Front Panel Replacement, Rear Case: adım 1, 1 resimden 1.
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Front Panel Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Front Panel Replacement: adım 3, 1 resimden 1.
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Front Panel Replacement, Battery: adım 4, 1 resimden 1.
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Front Panel Replacement, Front Panel: adım 5, 1 resimden 1.
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Front Panel Replacement: adım 6, 1 resimden 1.
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Front Panel Replacement: adım 7, 2 resimden 1. Sansa e260R Front Panel Replacement: adım 7, 2 resimden 2.
    • Pull the front cover away from the rest of the device.
Sonuç
Casey Smith
111 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-15, Maness Winter 2012 Cal Poly, Team 8-15, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G15
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,966
