Ana içeriğe geç
Sansa e260R Memory Board Replacement
Neye ihtiyacın var
  1. Sansa e260R Memory Board Replacement, Rear Case: adım 1, 1 resimden 1.
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Memory Board Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Memory Board Replacement: adım 3, 1 resimden 1.
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Memory Board Replacement, Battery: adım 4, 1 resimden 1.
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Memory Board Replacement, Front Panel: adım 5, 1 resimden 1.
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Memory Board Replacement: adım 6, 1 resimden 1.
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Memory Board Replacement: adım 7, 2 resimden 1. Sansa e260R Memory Board Replacement: adım 7, 2 resimden 2.
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Memory Board Replacement, Memory Board: adım 8, 2 resimden 1. Sansa e260R Memory Board Replacement, Memory Board: adım 8, 2 resimden 2.
    • Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
    • Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
  9. Sansa e260R Memory Board Replacement: adım 9, 1 resimden 1.
    • Pull the bottom of the motherboard up and then out.
  10. Sansa e260R Memory Board Replacement: adım 10, 1 resimden 1.
    • On the back of the motherboard, there is a rectangle of rubber.
    • Peel the rectangle off slowly.
  11. Sansa e260R Memory Board Replacement: adım 11, 1 resimden 1.
    • Under the rubber rectangle, there is a strip of black tape.
    • Peel the tape off about halfway so that it is no longer attached to the memory board.
  12. Sansa e260R Memory Board Replacement: adım 12, 1 resimden 1.
    • Carefully peel the memory board away from the rest of the motherboard
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
JenniferW
194 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-15, Maness Winter 2012 Cal Poly, Team 8-15, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G15
5 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
Admin User - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 2,585
