Ana içeriğe geç
Sansa e260R Scroll Wheel Replacement
Neye ihtiyacın var
  1. Sansa e260R Scroll Wheel Replacement, Rear Case: adım 1, 1 resimden 1.
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Scroll Wheel Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Scroll Wheel Replacement: adım 3, 1 resimden 1.
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Scroll Wheel Replacement, Battery: adım 4, 1 resimden 1.
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Scroll Wheel Replacement, Front Panel: adım 5, 1 resimden 1.
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Scroll Wheel Replacement: adım 6, 1 resimden 1.
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Scroll Wheel Replacement: adım 7, 2 resimden 1. Sansa e260R Scroll Wheel Replacement: adım 7, 2 resimden 2.
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Scroll Wheel Replacement, Scroll Wheel: adım 8, 2 resimden 1. Sansa e260R Scroll Wheel Replacement, Scroll Wheel: adım 8, 2 resimden 2.
    • Gently pry the bottom of the black button to remove it from the device.
  9. Sansa e260R Scroll Wheel Replacement: adım 9, 2 resimden 1. Sansa e260R Scroll Wheel Replacement: adım 9, 2 resimden 2.
    • There are 4 small metal hooks under the white scrolling mechanism.
    • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
  10. Sansa e260R Scroll Wheel Replacement: adım 10, 1 resimden 1.
    • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
JenniferW
194 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-15, Maness Winter 2012 Cal Poly, Team 8-15, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G15
5 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
Lloyd Merriam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 3,233
