Ana içeriğe geç
Sanyo Katana Back Casing Replacement
Neye ihtiyacın var
  1. Sanyo Katana Back Casing Replacement, Battery: adım 1, 3 resimden 1. Sanyo Katana Back Casing Replacement, Battery: adım 1, 3 resimden 2. Sanyo Katana Back Casing Replacement, Battery: adım 1, 3 resimden 3.
    • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
    • While holding down the button, pull cover off with other hand.
  2. Sanyo Katana Back Casing Replacement: adım 2, 3 resimden 1. Sanyo Katana Back Casing Replacement: adım 2, 3 resimden 2. Sanyo Katana Back Casing Replacement: adım 2, 3 resimden 3.
    • Use fingers to grip the battery and remove it from the phone.
  3. Sanyo Katana Back Casing Replacement, Back Casing: adım 3, 1 resimden 1.
    • Using a spudger, remove the four rubber coverings on the lower back plate.
  4. Sanyo Katana Back Casing Replacement: adım 4, 3 resimden 1. Sanyo Katana Back Casing Replacement: adım 4, 3 resimden 2. Sanyo Katana Back Casing Replacement: adım 4, 3 resimden 3.
    • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
  5. Sanyo Katana Back Casing Replacement: adım 5, 3 resimden 1. Sanyo Katana Back Casing Replacement: adım 5, 3 resimden 2. Sanyo Katana Back Casing Replacement: adım 5, 3 resimden 3.
    • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Preston
216 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G1
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 533
