Giriş
Removing the outer front case of the phone will reveal the LCD component of the device. The case can be swapped out with another of a the same or a different color.
Neye ihtiyacın var
With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
Use the spudger to pry off the front case from the left and right sides of the device.
Once it has popped off, pull the casing apart with fingers.
