Ana içeriğe geç
Sanyo Katana Front Case Replacement
Neye ihtiyacın var
  1. Sanyo Katana Front Case Replacement, Screen Protector: adım 1, 2 resimden 1. Sanyo Katana Front Case Replacement, Screen Protector: adım 1, 2 resimden 2.
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Front Case Replacement: adım 2, 2 resimden 1. Sanyo Katana Front Case Replacement: adım 2, 2 resimden 2.
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Front Case Replacement: adım 3, 2 resimden 1. Sanyo Katana Front Case Replacement: adım 3, 2 resimden 2.
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Front Case Replacement, Front Case: adım 4, 3 resimden 1. Sanyo Katana Front Case Replacement, Front Case: adım 4, 3 resimden 2. Sanyo Katana Front Case Replacement, Front Case: adım 4, 3 resimden 3.
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
Sonuç
StephenYH
20 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G1
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 248
