Giriş
The motherboard is the core component of the device, and removing it will not be an easy task. The keypad is attached to the motherboard and will remain attached at the end of this guide.
Neye ihtiyacın var
Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
While holding down the button, pull cover off with other hand.
Using a spudger, remove the four rubber coverings on the lower back plate.
Unscrew the 4.4mm screws at the top of the phone with the Tri-wing Y0 Screwdriver.
Open the phone and firmly hold the phone casing with one hand and push the motherboard out of the case with the other by pushing on the keys.
Once the keys are free from the casing, close the phone and pull the motherboard from the back of the phone the remainder of the way with your fingers.
Bir başkası bu kılavuzu tamamladı.
