Ana içeriğe geç
Sanyo Katana Screen Protector Replacement
Neye ihtiyacın var
  1. Sanyo Katana Screen Protector Replacement, Screen Protector: adım 1, 2 resimden 1. Sanyo Katana Screen Protector Replacement, Screen Protector: adım 1, 2 resimden 2.
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
    FixBot'a Sor
    Yorum Ekle
  2. Sanyo Katana Screen Protector Replacement: adım 2, 2 resimden 1. Sanyo Katana Screen Protector Replacement: adım 2, 2 resimden 2.
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Sanyo Katana Screen Protector Replacement: adım 3, 2 resimden 1. Sanyo Katana Screen Protector Replacement: adım 3, 2 resimden 2.
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
StephenYH
20 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G1
4 Üyeler
40 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 604
