Ana içeriğe geç
Sanyo Katana Screen Replacement
Neye ihtiyacın var
  1. Sanyo Katana Screen Replacement, Screen Protector: adım 1, 2 resimden 1. Sanyo Katana Screen Replacement, Screen Protector: adım 1, 2 resimden 2.
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
    FixBot'a Sor
    Yorum Ekle
  2. Sanyo Katana Screen Replacement: adım 2, 2 resimden 1. Sanyo Katana Screen Replacement: adım 2, 2 resimden 2.
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Sanyo Katana Screen Replacement: adım 3, 2 resimden 1. Sanyo Katana Screen Replacement: adım 3, 2 resimden 2.
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Sanyo Katana Screen Replacement, Front Case: adım 4, 3 resimden 1. Sanyo Katana Screen Replacement, Front Case: adım 4, 3 resimden 2. Sanyo Katana Screen Replacement, Front Case: adım 4, 3 resimden 3.
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
    FixBot'a Sor
    Yorum Ekle
  5. Sanyo Katana Screen Replacement, Screen: adım 5, 2 resimden 1. Sanyo Katana Screen Replacement, Screen: adım 5, 2 resimden 2.
    • Using a Tri-wing Y0 screwdriver, remove the 4.4mm screw.
    • Use fingers to remove the strip from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Sanyo Katana Screen Replacement: adım 6, 3 resimden 1. Sanyo Katana Screen Replacement: adım 6, 3 resimden 2. Sanyo Katana Screen Replacement: adım 6, 3 resimden 3.
    • Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen.
    FixBot'a Sor
    Yorum Ekle
  7. Sanyo Katana Screen Replacement: adım 7, 2 resimden 1. Sanyo Katana Screen Replacement: adım 7, 2 resimden 2.
    • Use the flat edge of the spudger to detach the screen from the phone casing.
    • Pull the screen up and away from the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Aliceann
49 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G1
4 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 77
Her zaman: 1,052
