Giriş
The speaker is a small, round piece that is easily detachable from the device. However, to access the speaker, various prerequisite steps must be completed.
Parçalar
Hiçbir parçaya gerek yok.
  1. Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone. While holding down the button, pull cover off with other hand. While holding down the button, pull cover off with other hand.
    • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
    • While holding down the button, pull cover off with other hand.
  2. Use fingers to grip the battery and remove it from the phone. Use fingers to grip the battery and remove it from the phone. Use fingers to grip the battery and remove it from the phone.
    • Use fingers to grip the battery and remove it from the phone.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Using a spudger, remove the four rubber coverings on the lower back plate.
    • Using a spudger, remove the four rubber coverings on the lower back plate.
  5. Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate. Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate. Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
    • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
  6. Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate. Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate. Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
    • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
  7. Gently tap the lower back casing on a hard surface to remove the speaker. Gently tap the lower back casing on a hard surface to remove the speaker.
    • Gently tap the lower back casing on a hard surface to remove the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Preston
216 İtibar
5 adet Kılavuz yazıldı
Takım
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G1
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 219
