Ana içeriğe geç
Sanyo S1414 LCD Replacement
Neye ihtiyacın var
  1. Sanyo S1414 LCD Replacement, LCD: adım 1, 3 resimden 1. Sanyo S1414 LCD Replacement, LCD: adım 1, 3 resimden 2. Sanyo S1414 LCD Replacement, LCD: adım 1, 3 resimden 3.
    • Remove the batteries and the memory card if so equipped.
    • Remove the two Phillips screws on the right.
    • Remove the four Phillips screws on the bottom.
  2. Sanyo S1414 LCD Replacement: adım 2, 3 resimden 1. Sanyo S1414 LCD Replacement: adım 2, 3 resimden 2. Sanyo S1414 LCD Replacement: adım 2, 3 resimden 3.
    • Remove the two screws on the left.
    • With all the screws removed, the case will split easy. No tool is required.
    • Front and back case come off at the same time. the silver midframe that houses the top buttons, remains on the camera.
  3. Sanyo S1414 LCD Replacement: adım 3, 3 resimden 1. Sanyo S1414 LCD Replacement: adım 3, 3 resimden 2. Sanyo S1414 LCD Replacement: adım 3, 3 resimden 3.
    • The LCD ribbon cable is folded under the holder. Do not try to remove the LCD yet. It will tear the ribbon cable.
    • Fold the LCD way from the holder. Remove the four screws that secure the holder to the logic board.
    • With the LCD holder out of the way, you can now open the ribbon cable connector. Use your fingernails to flip the white clasp away from the ribbon cable side. This will disconnect the cable. Remove the LCD and replace with the new one.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
oldturkey03
784.351 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
33 Üyeler
560 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,000
