Ana içeriğe geç
Sanyo SCP-8100 Keypad Replacement
Neye ihtiyacın var
  1. Sanyo SCP-8100 Keypad Replacement, Battery: adım 1, 3 resimden 1. Sanyo SCP-8100 Keypad Replacement, Battery: adım 1, 3 resimden 2. Sanyo SCP-8100 Keypad Replacement, Battery: adım 1, 3 resimden 3.
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Sanyo SCP-8100 Keypad Replacement, Back Panel: adım 2, 2 resimden 1. Sanyo SCP-8100 Keypad Replacement, Back Panel: adım 2, 2 resimden 2.
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
    FixBot'a Sor
    Yorum Ekle
  3. Sanyo SCP-8100 Keypad Replacement: adım 3, 1 resimden 1.
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Sanyo SCP-8100 Keypad Replacement: adım 4, 2 resimden 1. Sanyo SCP-8100 Keypad Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
    FixBot'a Sor
    Yorum Ekle
  5. Sanyo SCP-8100 Keypad Replacement: adım 5, 3 resimden 1. Sanyo SCP-8100 Keypad Replacement: adım 5, 3 resimden 2. Sanyo SCP-8100 Keypad Replacement: adım 5, 3 resimden 3.
    • While removing the back panel, take out the rubber cover on each side.
    FixBot'a Sor
    Yorum Ekle
  6. Sanyo SCP-8100 Keypad Replacement, Keypad: adım 6, 2 resimden 1. Sanyo SCP-8100 Keypad Replacement, Keypad: adım 6, 2 resimden 2.
    • Pull the volume and camera buttons off from the side of the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Sanyo SCP-8100 Keypad Replacement: adım 7, 2 resimden 1. Sanyo SCP-8100 Keypad Replacement: adım 7, 2 resimden 2.
    • Pull the gray frame covering the charging port from the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Sanyo SCP-8100 Keypad Replacement: adım 8, 2 resimden 1. Sanyo SCP-8100 Keypad Replacement: adım 8, 2 resimden 2.
    • Use the opening tool to lift the motherboard up from the phone.
    • Be careful and pry the motherboard off slowly. The motherboard will be attached to the phone at the top by a metal ribbon.
    FixBot'a Sor
    Yorum Ekle
  9. Sanyo SCP-8100 Keypad Replacement: adım 9, 3 resimden 1. Sanyo SCP-8100 Keypad Replacement: adım 9, 3 resimden 2. Sanyo SCP-8100 Keypad Replacement: adım 9, 3 resimden 3.
    • Flip open the phone, exposing the keypad.
    • Use the opening tool to push the buttons from the bottom to lift the rubber keypad up.
    • Pull the keypad out of the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Irenz Afable
57 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-41, Amido Spring 2013 Cal Poly, Team 10-41, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G41
4 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 670
