Ana içeriğe geç
Sanyo VPC S1275 Case Replacement
Neye ihtiyacın var
    1. Sanyo VPC S1275 Case Replacement, Battery: adım 1, 1 resimden 1.
      • Place your thumb on the right side of the camera over the battery door.
      • Slide the battery door to the right until the door lifts up.
      FixBot'a Sor
      Yorum Ekle
    2. Sanyo VPC S1275 Case Replacement: adım 2, 1 resimden 1.
      • Remove and recycle old batteries.
      FixBot'a Sor
      Yorum Ekle
    1. Sanyo VPC S1275 Case Replacement, Case: adım 3, 3 resimden 1. Sanyo VPC S1275 Case Replacement, Case: adım 3, 3 resimden 2. Sanyo VPC S1275 Case Replacement, Case: adım 3, 3 resimden 3.
      • Remove the following six screws using the Phillips #00 screwdriver:
      • Two screws on the left side of the camera.
      • Two screws on the right side of the camera.
      • Two screws on the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Sanyo VPC S1275 Case Replacement: adım 4, 2 resimden 1. Sanyo VPC S1275 Case Replacement: adım 4, 2 resimden 2.
      • Open the battery slot on the bottom of the camera by sliding the door to the right.
      • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Sanyo VPC S1275 Case Replacement: adım 5, 3 resimden 1. Sanyo VPC S1275 Case Replacement: adım 5, 3 resimden 2. Sanyo VPC S1275 Case Replacement: adım 5, 3 resimden 3.
      • Insert a spudger in the seam at the bottom of the camera.
      • Gently separate the rear case from the front of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Sanyo VPC S1275 Case Replacement: adım 6, 1 resimden 1.
      • This step is only needed for the case and logic board replacement
      • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
      FixBot'a Sor
      Yorum Ekle
    5. Sanyo VPC S1275 Case Replacement: adım 7, 1 resimden 1.
      • This step is only needed for the case replacement.
      • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
      • Slide the battery door off of the hinge.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ariana Martinez
50 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G24
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 31
Her zaman: 2,505
