Ana içeriğe geç
Sanyo VPC S1275 Function Set Replacement
Neye ihtiyacın var
    1. Sanyo VPC S1275 Function Set Replacement, Battery: adım 1, 1 resimden 1.
      • Place your thumb on the right side of the camera over the battery door.
      • Slide the battery door to the right until the door lifts up.
      FixBot'a Sor
      Yorum Ekle
    2. Sanyo VPC S1275 Function Set Replacement: adım 2, 1 resimden 1.
      • Remove and recycle old batteries.
      FixBot'a Sor
      Yorum Ekle
    1. Sanyo VPC S1275 Function Set Replacement, Case: adım 3, 3 resimden 1. Sanyo VPC S1275 Function Set Replacement, Case: adım 3, 3 resimden 2. Sanyo VPC S1275 Function Set Replacement, Case: adım 3, 3 resimden 3.
      • Remove the following six screws using the Phillips #00 screwdriver:
      • Two screws on the left side of the camera.
      • Two screws on the right side of the camera.
      • Two screws on the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Sanyo VPC S1275 Function Set Replacement: adım 4, 2 resimden 1. Sanyo VPC S1275 Function Set Replacement: adım 4, 2 resimden 2.
      • Open the battery slot on the bottom of the camera by sliding the door to the right.
      • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Sanyo VPC S1275 Function Set Replacement: adım 5, 3 resimden 1. Sanyo VPC S1275 Function Set Replacement: adım 5, 3 resimden 2. Sanyo VPC S1275 Function Set Replacement: adım 5, 3 resimden 3.
      • Insert a spudger in the seam at the bottom of the camera.
      • Gently separate the rear case from the front of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Sanyo VPC S1275 Function Set Replacement: adım 6, 1 resimden 1.
      • This step is only needed for the case and logic board replacement
      • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
      FixBot'a Sor
      Yorum Ekle
    5. Sanyo VPC S1275 Function Set Replacement: adım 7, 1 resimden 1.
      • This step is only needed for the case replacement.
      • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
      • Slide the battery door off of the hinge.
      FixBot'a Sor
      Yorum Ekle
    1. Sanyo VPC S1275 Function Set Replacement, Function Set: adım 8, 2 resimden 1. Sanyo VPC S1275 Function Set Replacement, Function Set: adım 8, 2 resimden 2.
      • Remove the function set strip by lifting it from the inside of the rear case.
      • The function strip is now free from the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ariana Martinez
50 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G24
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 3,200
