Ana içeriğe geç
Sanyo VPC S1275 Function Set Replacement
Neye ihtiyacın var
  1. Sanyo VPC S1275 Function Set Replacement, Battery: adım 1, 1 resimden 1.
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 Function Set Replacement: adım 2, 1 resimden 1.
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 Function Set Replacement, Case: adım 3, 3 resimden 1. Sanyo VPC S1275 Function Set Replacement, Case: adım 3, 3 resimden 2. Sanyo VPC S1275 Function Set Replacement, Case: adım 3, 3 resimden 3.
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Sanyo VPC S1275 Function Set Replacement: adım 4, 2 resimden 1. Sanyo VPC S1275 Function Set Replacement: adım 4, 2 resimden 2.
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Sanyo VPC S1275 Function Set Replacement: adım 5, 3 resimden 1. Sanyo VPC S1275 Function Set Replacement: adım 5, 3 resimden 2. Sanyo VPC S1275 Function Set Replacement: adım 5, 3 resimden 3.
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 Function Set Replacement: adım 6, 1 resimden 1.
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. Sanyo VPC S1275 Function Set Replacement: adım 7, 1 resimden 1.
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
  8. Sanyo VPC S1275 Function Set Replacement, Function Set: adım 8, 2 resimden 1. Sanyo VPC S1275 Function Set Replacement, Function Set: adım 8, 2 resimden 2.
    • Remove the function set strip by lifting it from the inside of the rear case.
    • The function strip is now free from the camera.
Sonuç
Ariana Martinez
50 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G24
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 2,660
