Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to replace the function set.
Parçalar
Hiçbir parça belirtilmedi.
  1. Place your thumb on the right side of the camera over the battery door.
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Remove and recycle old batteries.
    • Remove and recycle old batteries.
  3. Remove the following six screws using the Phillips #00 screwdriver: Two screws on the left side of the camera. Two screws on the right side of the camera.
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Open the battery slot on the bottom of the camera by sliding the door to the right. Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Insert a spudger in the seam at the bottom of the camera. Gently separate the rear case from the front of the camera. Gently separate the rear case from the front of the camera.
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. This step is only needed for the case and logic board replacement
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. This step is only needed for the case replacement.
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
  8. Remove the function set strip by lifting it from the inside of the rear case. The function strip is now free from the camera.
    • Remove the function set strip by lifting it from the inside of the rear case.
    • The function strip is now free from the camera.
Sonuç
Ariana Martinez
50 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G24
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 2,470
