Ana içeriğe geç
Sanyo VPC-S1415 LCD Replacement
Neye ihtiyacın var
    1. Sanyo VPC-S1415 LCD Replacement, LCD: adım 1, 3 resimden 1. Sanyo VPC-S1415 LCD Replacement, LCD: adım 1, 3 resimden 2. Sanyo VPC-S1415 LCD Replacement, LCD: adım 1, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Here is a recently acquired camera. Initial cost $3.00
      • Only trouble is, obviously broken LCD
      • Remove the carrying strip. Use a needle and some tweezers to loosen the slip knot.
      FixBot'a Sor
      Yorum Ekle
    2. Sanyo VPC-S1415 LCD Replacement: adım 2, 3 resimden 1. Sanyo VPC-S1415 LCD Replacement: adım 2, 3 resimden 2. Sanyo VPC-S1415 LCD Replacement: adım 2, 3 resimden 3.
      • Remove one screw on the right of the camera
      • Remove one screw on the left side of the camera
      • Remove the two screws on the bottom
      FixBot'a Sor
      Yorum Ekle
    3. Sanyo VPC-S1415 LCD Replacement: adım 3, 3 resimden 1. Sanyo VPC-S1415 LCD Replacement: adım 3, 3 resimden 2. Sanyo VPC-S1415 LCD Replacement: adım 3, 3 resimden 3.
      • Split the camera from the battery compartment down. You can use an opening tools, or just your fingernails, if so equipped.
      • This will remove the front part of the case.
      • Remove this screw on the right side of the camera. Keep it separate from the 4 screws previously removed. The are of different length
      FixBot'a Sor
      Yorum Ekle
    4. Sanyo VPC-S1415 LCD Replacement: adım 4, 3 resimden 1. Sanyo VPC-S1415 LCD Replacement: adım 4, 3 resimden 2. Sanyo VPC-S1415 LCD Replacement: adım 4, 3 resimden 3.
      • Remove the screw on the bottom of the battery compartment. Keep this screw with the one removed on the previous step. These two screws have a different length than all the other screws. They are the shortest ones in the camera
      • With those two screws removed, you can not separate the back part of the case.
      • Flip the LCD to the right and out of the frame. Do NOT try to remove it yet.
      • Remove the screw screws that hold the LCD frame to the logic board. Keep the 3 screws separated from the rest of the screws, due to different length.
      FixBot'a Sor
      Yorum Ekle
    5. Sanyo VPC-S1415 LCD Replacement: adım 5, 3 resimden 1. Sanyo VPC-S1415 LCD Replacement: adım 5, 3 resimden 2. Sanyo VPC-S1415 LCD Replacement: adım 5, 3 resimden 3.
      • With the frame removed, the connector and LCD cable are now fully accessible. Note the to tabs on the cable and their position on the logic board.
      • Flip the tab on the connector carefully up and remove the LCD.
      • Hopefully this is what you will get after replacing the LCD and reassembling the camera in reverse order. Total replacement cost was $15 and 30 minutes of my time.
      FixBot'a Sor
      Yorum Ekle
Sonuç
oldturkey03
858.602 İtibar
123 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 2,672
