Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Locate the hatch found on the bottom of the camera.
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. STUDY UNPLUGGED
    Battery Fix Kits for Mac
    Shop Fix Kits
    STUDY UNPLUGGED
    Shop Fix Kits
  4. Push the small, plastic arm out of the way to free the battery.
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  5. Pull the battery out of the camera and close the hatch.
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
Sonuç
James Robinson
432 İtibar
4 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 265
